Baking tray on the shelf underneath you genius!
Use your common![]()
threepost!
Cook your pizza on a wire rack instead of a baking tray. They come with your oven.
*n
fan assisted ovens are the way to go.your impatient lol
Or just make your own pizza from scratch? Doesnt taste like **** - a frozen lump of bread with greasy-ass cheese jizzed all over it, and much better for you, as well as being perfectly cooked all the way through.
although busy parents dont have the time and would rather buy a £3 pizza from asdas they can chuck in the oven.
welcome to the real world, and the majority of the UK.
proper thin base pizzas dont suffer soggy middle.
only them nasty pizza wedges... loafs of bread with a bit of cheese on.
No no no sir, frozen deep pan are prone to soggy middle. real pizza will not
Unless your completely useless and given up on life you wont get soggy wet thin pizza
I've got a round pizza tray, with holes in it![]()
The more I think about it, the more I think the dragons made a massive mistake on this one![]()
to be fair they only need to get 200,000 people to buy one and they will break even. not that 25k matters much.
im pretty sure there are 200,000 people/muppets around to part with £2
I'd buy that for a dollar.
id welly rather buy a £1 frozen piece of crap pizza from iceland than spend a fiver on ingriedients and an hour making, cooking and then cleaning up a "homemade" one
a fiver on ingredients?
You dont go shopping much do you....
what are we putting on this pizza?
you cant compare a cheap and nasty £1 pizza with a large one with a decent base, stuffed crust, rammed with loads of decent NUTRITIOUS toppings for £5.
except to a single mum on benefits that £5 buys 5 pizzas to feed her sprogs.
