- 7 Nov 2004
- Southampton/Oxford
am considering buying these but i want to know the size of the sub so does anyone have piccys of it at your setup?
Please note: Logitech Z5500 Sub-Woofer is quite large, please check before purchasing. Logitech Z5500 Subwoofer dimensions: 13" X 13.3" X 18.1"
lol. I knew that was coming5500 is quite a small subwoofer.
lol. I knew that was coming![]()
You say that as if they refuse to play music.If you want them for movies and games then go go go , if you listen to loads of music then a second hand 2.0 speaker setup with a hi-fi amp would be better suited.
Babbob, can't quite seem that sub, looks a little small TBH
I guess the 5500 in PC audio terms is a big sub but for HT it's classed as a small-to-medium sized sub. Not sure the size of this but that's a 12" driver, and there are four of them.
http://i47.photobucket.com/albums/f184/badbobsausage/b4l2rosewood3dq.jpg
6'6" tall tapped horn, not pretty but it works:I guess the 5500 in PC audio terms is a big sub but for HT it's classed as a small-to-medium sized sub. Not sure the size of this but that's a 12" driver, and there are four of them.
Stuff that! The carpet, wallpaper and glass window/frame looks more awesome!That cylinder one looks awesome.![]()
