Dell 2408 A01 or Hazro HZ24W
Dell have started shipping REV A01 they will be clearly marked on the Dell packing label and on the monitor - read the Official 2408WFP Majik has receievd the first A01 Marked "REV A01" and has the correct sharpness settings (multiples of 10)
Err, not necessarily.
http://forums.overclockers.co.uk/showthread.php?t=17841904&page=16
"The quote from the member of staff at Dell: Due to a Dell internal process change many of the 2408's that will ship new with the revised firmware will have a different part number and not a different revision number. The only way you will be able to tell if it's the revised firmware is to check the sharpness setting, if the setting is in multiples of 10 then it is the revised firmware if it's in multiples of 25 then it's not. The part number has nothing to do with the revision but someone decided since we are changing the part number anyway the firmware will be A00 on that part number."
They really need to hurry up with this as I am getting sick of waiting, im going to email dell now and find out what the chances are of getting a newer screen if I order now.
I'm starting to sway towards the Hazro now. Not sure about the 24" glossy screen though, might have to get the 26", and wall mounting it seams a bit 'silly'..... They don't make it easy do they!?
Indeed they dont, its a shame my desk faces my window as well so im going to have the light bouncing off it all over the place
Thats the ting tho, its an extra £100 and my desk isnt really big enough for it, supposedly the gamut thing on it makes games look abit rubbish as well going from the other hazro thread :(
Nooo, don't say that!
24" glossy
26" Poor for gaming?
I just don't know what 24" to buy :mad:
Get yourself the Hazro 24".
There is a lot of ney saying on the "any word on the Hazro update" thread but several people have made some long, calm and well thought out posts essentially stating that the banding issue is not real world and only shows up in artificial tests.
if you stop trying to find it you wont find it.
as for the glossy screen - the laptop im using right now has a screen like a mirror on it, its that glossy. With that said I can use it on the train right by the window and it makes all colours look very vibrant and nice.
In a normally lit room i sometimes catch a cieling light in the screen - but its cos its a laptop and you need to tilt the screen back due to itbeing so close (attached to the keyboard). you wont need to do this with the hazro and it will thus be flat and pick up far less refections.
all in all the glossy is nice and i dont have an issue at all from using my glossy laptop screen. which is why im buying a 24" hazro tomorrow.
Dam
Pretty impressed with my Hazro so far tbh. wathced some high def previews from quicktime.com/trailers today :) ontop of playing some cod4, its awesome!
first out of the box at work. apologies for iphone photo :(
