Response time question
4 Aug 2006
If current LCDs run at 60hz, why is a response time of less than 16ms even important? Surely you won't even see any frames rendered between the updates at 1/60th (16ms) per second??
Your eyes continue to send an image to the brain for 10ms after the image has gone.
If the response time is too slow then you'll see both the old image and the new image for the frame for most of the frame length.
Frame length + image persistance would be 26ms from 32ms (two frames) so your eyes would register two images 81% of the time ....
AD
ah this old gem :p response time and refresh rate are different things, dont get them confused :) have a read here which should help http://www.tftcentral.co.uk/specs.htm
Cheers for that. Good guide. I did realise that they were different - was just interested in how the relate to each other.
From what I can gather, the 60hz is how many images (maximum) are displayed per second, and the response is how quickly each specific image is drawn. So theoretically at least, as long as your response time is less than 16ms, you will still get your image drawn and undrawn(?) within the time it takes to move to the next image. A faster response time will just create less ghosting / give a crisper image.
It appears with todays LCD's and the way they work that you always 'see' the old and new image. This is the reason behind black frame interleave research etc.
Here's my favourite article on LCD tech, page 3 for retinal retention / persistence of vision. A very informative article if anyone cares to spare the time...
http://www.xbitlabs.com/articles/monitors/display/lcd-parameters.html
