ASUS Striker II Extreme Or EVGA nForce Ultra???
I am running sli and have a very stable 3.375 overclock on air.And when funds allow I will be water cooling this lot.And push it further. But I bought the newest chipset MB / mem and gpu as I intend on keeping this setup for a couple years.Not every 1 can upgrade every other week. As said in another post I am overclocking it a small amount at a time running it for a few days stable before pushing it a bit more, One step at a time, 24/7 stability is what i want not to just bench it.
Any help on pushing it further is appreciated.
You want some settings for 3.6GHz? :)
EASILY attainable with the rest of the kit you have mate :)
Ok, try this and let me know:
AI Overclock Tuner: Manual
FSB Mem Clock: Unlinked
FSB: 1600
Multiplier X 9
RAM: Whatever your RAM'S stock speed is
PLL Voltage: 1.38
VTT Voltage: 1.5
CPU VCore: 1.465V
RAM Voltage: Stock
NB: Auto
SB: Auto
Same as any water cooling venture mate - carefully - and test the loop fully before whacking it all in the case.
The top of the block does appear to be a softer metal than most blocks. Overtightening the connections would certainly cause a rupture if forced.
I'll see what I can do about the 790i guide. You having problems? Try some settings of mine if you like :)
No problems yet mate, do you reckon this board will do 450fsb with just the CPU under water. Leaning away from using the FB. If it goes pear shaped I cant afford to replace this board.
Thanks for the guide btw.
Easily.
You won't kill the board with heat mate. Look in the BIOS....there are thermal cut outs for NB, SB etc :)
What are you clocked at?
Try a couple of posts above for 3.6GHz settings :)
Easily.
I meant killing the board with leakages around the fusion block, rather than heat mate. :)
Ive only got a stock intel cpu cooler so havent overclocked this board yet. Been playing in the bios and its certainly the best I've bios Ive experienced so far. Been waiting for my EK res to arrive, which it just has, so when Ive rigged up my loop again I'll try your settings.
And how far would that guide have let you overclock a Q6600 when they were released a couple of months later?
Assuming you got a board that didn't have flakey USB ports, didn't kill your RAM when overclocking, or goose your OS because of the flakey SATA ports.
The Rev1 boards were so bad, EVGA if I remember correctly offered to replace every single one with a Rev2 when they came out.
FSB: 1600
Multiplier X 9
PLL Voltage: 1.38
VTT Voltage: 1.5
CPU VCore: 1.465V
RAM Voltage: Stock
NB: Auto
SB: Auto
You seem to be in the know Andy, what board would you buy ASUS or EVGA?
EVGA is the Nvidia reference board rebadged and re packaged.
The Asus has a modded BIOS and better onboard audio card bundled (unless u r using an X-Fi)
If you are a seasoned OC'er, probably not much in it tbh :D
I think this is where the Evga 790i F.T.W comes in nicely actually. Better board than the referance (Not sure on it's specs compared to the Striker) but it will be cheaper than both and better for overclocking quads.
Oh well.... decision made....
I bought the ASUS Striker II Extreme with 4Gb Corsair DDR3...
Thanks for the replies all!
Regarding the fusion block, general consensus is that it's copper-plated Aluminium which is why many people are hesitant to use it. If the copper is slightly scratched or badly applied it will lead to galvanic corrosion is someone isn't expecting it.
But no official word from Asus, it's just speculation so far.
Personally I'm going with the S2E over the reference board, while the reference board has the advantage of being able to use the nVidia drivers rather than having to wait for a third party to adapt them, I prefer the look and features (dual-eSATA for example) of the S2E :)
agreed
I doubt its a copper-plated aluminium block, its way way too heavy to be aluminium. In fact Ive read a post on xtremesystems by a guy who claims to have sawn through the block confirming that it is indeed copper.
Bitspower have some very nice looking blocks coming out for both the reference and Asus boards, probably worth investing in if you're going to the effort of WCing.
