Steam (Team Fortress 2) & Vista x64...
I used to get the damn error on Vista x32 so I stuck it on the DEP list and that solved issues. However that fails to work in x64 so I guess I was 'lucky' with my whole DEP trick.
That trick has worked for me on XP x64, most wierd.
Try also adding these cmmds the launcher but with your own values ofc:
-novid -width 1024 height 768 -refresh 85
On 64 aswell and have had a lot of ctd's, seems to be better now.
I also put this line into the windows cmd prompt net localgroup administrators NetworkService /ADD
I dont know exactly what it does, just that i havent had side effects from it yet, so only do it if you find out what it does and feel your PC will be ok with it.
I heard about that when having a look around last night. I added it. Played for about an hour this morning and just about to heal when it happened again. I hear the hard drive seconds before, then pauses... then the error :(
