bought a htc touch pro sim free for payg ...
27 Nov 2007
Manchester
and after the internet wasn't working rang up o2 who said because it's not on one of their contracts it's not supported.
surely some network will support it and carry the internet on a payg plan?
anyone else buy a htc touch pro sim free? what are you guys doing about mobile internet?
cheers.
Full internet is not supported on PAYG but FYI if you change to o2 contract -
O2 GPRS settings (Email/Web):
Homepage: http://pda.o2.co.uk/
APN address: mobile.o2.co.uk
Username: mobileweb
Password: password
Session type: Continuous / permanent
Authentication: Normal
Security: Off
Email servers (POP): mail.o2.co.uk
Email servers (SMTP): smtp.o2.co.uk
DNS Servers: 193.113.200.200 and 193.113.200.201
Note: The "Mobile Web" service must be enabled for these settings to work.
* We've also been told of an alternative username of 'faster', with a password of 'password'
Contact o2 Customer Services to get this enabled. Not available on PAYG
Username: mobileweb
Password: password
Security: Off
awesome, cheers teledude ... shame it won't work though :( don't suppose you have any idea if this is going to be the same for all networks? please don't say i just bought it sim free wanting to use it on payg and am not going to be able to get the internet working ...
Why not get O2 Simplicity, that way you aren't tied to a contract (well, 1 month notice to cancel I think) and will be able to use o2 web access.
I couldn't tell you tbh - off the top of my head I think you can get web n' walk payg from tmobile :)
Sent an email to t mob to see what they say - thanks.
Orange and Vodafone sell it on contract, so maybe give them a ring and ask?
Cheers stellios .. i have a post on the voda forum and will get in contact with orange to check.
Yeah i've seen about o2 simplicity meeko but in all honesty i don't know if i'd use that amount of texts/minutes and it's too expensive for me. also they said because atm the htc touch pro isn't supported by o2 they have no settings for it anyway ..
it will be supported by o2 as long as you have a contract you can use the settings above :)
nah mate it was a gift from parents for results, i know how it seems :)
Ah lucky you.
WAP settings:
O2 WAP settings (GPRS):
Note: Different settings for contract and PAYG (Pay as you go)
Homepage: http://wap.o2.co.uk/
APN address (contract): wap.o2.co.uk
APN address (PAYG): payandgo.o2.co.uk
Gateway (IP) address : 193.113.200.195
Username : o2wap (contract) / payandgo (PAYG)
Password: password
HTTP Proxy: 193.113.200.195
Port number: 8080
more info:http://www.filesaveas.com/o2wap.html
Ah lucky you.
WAP settings:
Password: password
Port number: 8080
awesome cheers thought ... i'll have a run through this now ..
been trying it mate but still no luck .. there's certain settings that i can't see where to input them or there are others i need .. i'll try and get some screenshots up ...
cheers
just found this for orange though .. bearing in mind the Touch Pro is just a Diamond with a keyboard;
http://orangeotm.wdsglobal.com/oran...guageId=261&captchaEnabled=false&phoneId=2286
EDIT : awesome thanks to thought and to orange but through using the url thought gave us and orange's instructions i got it working ! YAY! cheers guys as always
1. On the handset, tap Start and select Settings.
2. Tap the Connections tab.
3. Tap the Connections icon.
4. Tap the Advanced tab.
5. Tap Select Networks.
6. Under the first drop down box, tap New…
7. In the Enter a name for these settings: field, enter Orange GPRS WAP
8. Tap the Modem tab.
9. Tap New…
10. In the Enter a name for the connection: field, enter Orange GPRS WAP
11. Tap the Select a modem drop-down list and select Cellular Line (GPRS, 3G).
12. Tap Next.
13. In the Access point name: field, enter orangewap
14. Tap Next.
15. If required, in the User name: field enter
16. If required, in the Password: field enter
17. Tap Finish.
18. Tap the Proxy Settings tab.
19. Select the This network connects to the Internet option.
20. Select the This network uses a proxy sever to connect to the Internet option.
21. Tap Advanced… Tap on HTTP.
22. In the Proxy server field, enter 192.168.071.035
23. In the Port field, enter 8080
24. Tap ok five times
25. Tap x to close the Settings screen.
26. Tap Start, then launch Internet Explorer.
27. Tap Menu.
28. Tap Favorites...
29. Tap the Add / Delete tab.
30. Tap Add...
31. In the Name field, enter Orange World
32. In the Address field, enter http://orangeworld.co.uk
33. Tap Add.
34. Tap ok.
35. Tap x.
Which is just a Windows Mobile device so settings and instructions will be the same for any WM device.
What level of internet access do you get with the above settings and what's the rough cost? Does you get 3G/HSDPA? What's the data charge?
i'm not sure mujja. it shows HSDPA in my area and it seems relatively quick - not cheap though i went onto a single weather site and it was 40p to put it into context. think o2 it's £4 a mb
That's expensive.
You would have been better off with a free handset + contract with unlimited data.
I some how managed 40MB of data just web surfing in my first full month. The opera browser is great and loads pages in seconds. I don't even bother with the wifi sometimes when at home.
how u getting on with the phone? I really want one but orange aren't getting it and I want to stay with orange
That's expensive.
Mate, if I could get a £5 a month deal just for web browsing i would so jump on it but unfortunately I'd have to take out a deal with minutes/texts which wouldn't really be viable for me atm.
Really well mate .. i just go to xda devs for any help and i get a quick helpful reply. phone itself is awesome, using the internet is a breeze through opera on it.
have a look at three payg its what i put into my kaiser......i top up £25 a month for 700 minutes and top up £5 for internet for the month....
Not that much worse than contract deals. for those that dont want a contract
