been trying it mate but still no luck .. there's certain settings that i can't see where to input them or there are others i need .. i'll try and get some screenshots up ...
cheers
just found this for orange though .. bearing in mind the Touch Pro is just a Diamond with a keyboard;
http://orangeotm.wdsglobal.com/oran...guageId=261&captchaEnabled=false&phoneId=2286
EDIT : awesome thanks to thought and to orange but through using the url thought gave us and orange's instructions i got it working ! YAY! cheers guys as always
1. On the handset, tap Start and select Settings.
2. Tap the Connections tab.
3. Tap the Connections icon.
4. Tap the Advanced tab.
5. Tap Select Networks.
6. Under the first drop down box, tap New…
7. In the Enter a name for these settings: field, enter Orange GPRS WAP
8. Tap the Modem tab.
9. Tap New…
10. In the Enter a name for the connection: field, enter Orange GPRS WAP
11. Tap the Select a modem drop-down list and select Cellular Line (GPRS, 3G).
12. Tap Next.
13. In the Access point name: field, enter orangewap
14. Tap Next.
15. If required, in the User name: field enter
16. If required, in the Password: field enter
17. Tap Finish.
18. Tap the Proxy Settings tab.
19. Select the This network connects to the Internet option.
20. Select the This network uses a proxy sever to connect to the Internet option.
21. Tap Advanced… Tap on HTTP.
22. In the Proxy server field, enter 192.168.071.035
23. In the Port field, enter 8080
24. Tap ok five times
25. Tap x to close the Settings screen.
26. Tap Start, then launch Internet Explorer.
27. Tap Menu.
28. Tap Favorites...
29. Tap the Add / Delete tab.
30. Tap Add...
31. In the Name field, enter Orange World
32. In the Address field, enter
http://orangeworld.co.uk
33. Tap Add.
34. Tap ok.
35. Tap x.
