Only reason I would consider this upgrade is that the minimum FPS at low res are higher with a GTX280 according to all the reviews. This is important if like me you are not running at a high resolution so I am also considering it as an upgrade option but the things which puts me off are the potential issue with Nvidia cards failing because of the manufacturing faults as reported on theinq and not being able to use a 3rd party HSF yet.
