Have you heard a Corsa revving? :O
They have an amusing squeak when the throttle body opens, sounds like a guinea pig
Isn't the BMC CDA fairly expensive and also not really going to offer any decent gains at all.
just leave it, save your money.
9bhp.. lol, dunno what that mate was on about. 25 bhp.. Well is a k+n air filter worth it. Only like £50 and doesnt it make it cleaner and sound a bit nicer?
how much would one of those cost and how much performance would it increase the car by? Cheers
Have you heard a 318 revving :O
Yes, both engine types and mine sounds perfectly fine fyi, want a soundbite or something...
infact some of the biggest gains from remaps can be had on the VAG diesels.
Really? All the 318s I've heard sound papA bit like my Leon really
It doesn't sound like a 4cylinder car you'd probably expect, sounds more nicer though it doesn't sound like a VTEC kind of nice either but it is much nicer sounding than other 4cylinders.
I'll post a recording up after work if it stops raining today*
Remapping a run of the mill naturally aspirated engine will never yeild noticable results.
What do they make after a map? (bearing in mind that the Mini ONE was an electronically castrated Mini Cooper engine, i'd rather know what the Cooper makes pre and post map)
cooper is quoted 10bhp, so probably about 8bhp
it is true about the mini one though, its just electronically restricted, so a map will give it about a 30bhp increase
