Noahs Ark and Rain question
  • Thread starter Thread starter Zip
  • Start date Start date
There is however, enough bull**** in the Christian world...
Yes!
The world is only 6,000 years old, not like those pesky scientists would have you believe with their "evidence".
And don't even get me started on creation scientists: "This old cloth carbon dated to about 1300AD is the shroud Jesus was wrapped in after being nailed to a cross because I can hang a guy from a cross by nailing through a special leather glove proving that the hands are strong enough to hold a nail, and that the blood stains are in the right place."
I know there are people out there that do and dont believe Noahs ark, But this thread isnt about that.
Its just a question i thought up while sitting on the hill at work:p
How many Mililitres of rain a day would there have had to had to flood the world in 40 days?:D
(I chose Mililitres because thats how rain is normally messured, Unless you use points. Either way you can convert them)
Get thinking people:)
Rain is measured in millimetres, not millilitres.
So enough water to fill the souil so that the water table was at ground level, plus however high you want the water to go.
Rain is measured in inches in the UK. Long live Imperial measurements!
No they make your job a pain in the hole when you've been taught to use the metric system. And sourcing production equipment in imperial mesurements is an absolute nightmare.
Also, you can't spell bible without lie.
Back then the World was flat, so surely all the excess water would simply have fallen off the sides, also it only took six days to create, so it wouldn't really be too much trouble to knock up a new one.
Mount Everest is 8846m above sea level, so in order to completely flood the Earth the sea levels would need to rise this much.
You can calculate the volume of a sphere using the formula 4/3 pi r^3. So the total extra volume you'd need to fill is 4/3 pi 8846^3, which is 2.90x10^12m^3 (2.90x10^18 mililitres). And that only works if you forget the fact that the rain will be coming from the sea in the first place.
According to the US Geological survey there is 326 000 000 cubic miles (1.36x10^18m^3)of water currently on Earth. Which is quite a bit more then I was expecting! I was hoping to show that even if you forget that the sea levels would drop when the massive rain clouds initially formed and would just cycle at the same level once the rain started there still wouldn't be enough water but it seems there is. Damn watery Earth!
World Surface area: 510,072,000 km²
High of highest land: 8,848 m
Then you'd need to take out the space that is currently occupied by land above sea level so you could work out how much rain would be needed to fill the earth until no land was above the water to get a vague idea.
You don't need to worry about the volume of the Earth itself, it drops out the formula in the calculation so you can just take the volume required to fill the layer above the Earth to be the same as a sphere of radius 8848m.
How big would this ark have had to been to contain 2 of every animal in the world? London Zoo is a fairly large place and it doesn't have 2 of every animal in the world.
It was more than two, anyway. "Two" is yet another mistranslation.
This, of course, assumes that god moved some of every animal in the world to Noah's back yard and somehow made it possible for them to live outside their environment, on a boat.
And they all ate nothing, drank nothing and excreted nothing the whole time. Somehow.
The story is monumentally ludicrous and anyone who believes it as it is written is mad.
Maybe there was a local (though very large) flood and someone put some of their own farm animals on a boat. Those animals would be their wealth, even their survival.
Maybe humanity originated on another planet and Noah's ark was a spaceship with samples of a number of examples of every animal on that planet, to be somehow reconstituted on Earth from the genes up.
