Newish Samsung F1 500GB failing already?
12 Aug 2008
Northern Ireland
So my PC is running fine, not noticeably slower or anything at all and then today I get a nice little message from S.M.A.R.T when I boot telling me that the drive is about to fail. I ignored this and when vista had loaded I got a similar message saying that I should backup all my files, cause it's likely the drive will fail.
Anyway as I said above I don't see any performance decrease or any slowdowns whatsover. I ran hdtach just to see if there was any decrease in performance and it's basically the same as before with slightly higher burst rate and a slightly increased access time.
Should I just keep using it until I do run into problems or it does actually fail, or would it make sense to RMA it now?
oh and I have made a backup of everything on the drive just in case ;)
Doesn't sound good.
I have an F1 500GB that showed 6 bad sectors within a few weeks of installing it, but it hasn't developed any more than that.
I'd certainly not be trusting that drive.
Hdtune is reporting a fault on the disk.
Don't have a clue what that part does but its way below the treshold. Anyone know anything about that?
Just thought I would update this. Sent the drive off to Rexo, cost £6.40 for recorded delivery.. they received it the next day and posted the new one out the same day. Must say I am impressed with how quick they got it sorted, but then again they are a company setup just for returns :)
Anyway hopefully this drive should last me a bit longer, lol... otherwise its WD drives for me from now on.
Are they going to give you your £6.40 back?
As it was not your fault the HD is dead or am I missing something here
Distance selling act - they are legally obliged to return the postage for returns of faulty items.
On a note of the HDD, i built a server recently with 3 in RAID5 and within 2 months 1 of them has failed - not good, but i hope its an isolated incedent and not a repeat of the deskstar drives of old!
Don't think distance selling would apply to this, and even if it does, I don't think you're correct about return postage.
If it was purchased through the internet (rather than in store) then distance selling does apply, and i am correct about the return postage on faulty items i guarantee you as i've worked for and have a large vested interest in a long running mail-order/internet business.
Another update... got the replacement drive on monday and the read/write speeds and access times were far worse than the original :(, so I bought a WD RE3 320GB afer having seen some good reviews and I'm very happy I did.
I just seem to have bad luck with samsung drives :) as I know many people love them... anyway I didn't get rid of the 500GB F1, I'm just gonna use it for storage and run vista on the WD drive.
Just found this thread and mine is failing on exactly the same thing on HDTune. Going to send it back - you ssaid you sent it to Rexo , do you have any details?
Enter your serial number to double check warranty and then register and request an RMA...
http://rexo.co.uk/warranty.php
Your serial number can be seen on the Info tab in HDTune, saves you having to unplug the drive etc :)
Thanks. I can't run Samsungs bootable software - estool, quick search shows neither can a lot of people. Atleast it looks like they will accept the fault based on HD Tune.
To cut a long story short, the ESTool ISO's built-in DOS-mode CD/DVD drivers aren't completely compatible with all optical drives, so it's a bit hit-and-miss as to whether the CD version will work.
If you don't have a floppy drive, you can still run it by making a bootable USB flash drive by following the instructions here, and copy the ESTool executable onto it from the CD you created.
It's probably not strictly necessary though, I'm sure a SMART failure as per your own thread will be all the information needed. :)
