) are big enough and have suitable response to reach the sub crossover frequency leaving no typical low-midrange dropout; the buyoff being maximum output due to the inherent low sensitivity of such a driver. This isn't a problem for my application. Another potential issue with them is off axis response, the treble does dull off axis since these are relatively large drivers to cover up to 20khz (3"). If these arn't big issues then I'd reccomend them though, what i'm hearing so far is very clear and detailed, voices sound great
Well right now I'm sort of halfway there, I already have some Mordaunt-Short MS302 satillites which are pretty similar to the B3N's I imagine, apart from that they are 2-way (3" mid, + tweeter), but they sound quite nice when connected up to the Amp9B.Mike, thats cool, whats your requirement for them? I can't take big Hi-Fi gear to a student house but want something decent and compact. Unfortunately most commercial offerings are built very poorly and DIY is more fun!
The B3N's that I'll use for satellites (match the sub too) are big enough and have suitable response to reach the sub crossover frequency leaving no typical low-midrange dropout; the buyoff being maximum output due to the inherent low sensitivity of such a driver. This isn't a problem for my application. Another potential issue with them is off axis response, the treble does dull off axis since these are relatively large drivers to cover up to 20khz (3"). If these arn't big issues then I'd reccomend them though, what i'm hearing so far is very clear and detailed, voices sound great
 The sound is very good through my HD-580s...I was expecting some background noise but there really is none at all! And it's running from the line-out on my onboard P5Q deluxe sound
 I have an ebay DAC that's arrived here so that's my next thing to do.
 I did mess up on the LED hole though, made it too big. I might look for a larger LED to fill the hole up some more.
 I'm eager to hear something tube powered as I hear the HD 580s really show their true colors with tubes.
I've got my Amp6 working, been listening to it all week and i can't believe the sound quality coming out of it, it's much better than my Yamaha AV amp! I know people said that AV amps are no good for music, but i didn't expect so much difference.
I've been bitten now, i want to build some thing else.
I need some help with my DAC though.
When i connect the RCA's to the input of the amp, the volume is to loud, even with every thing turned down.
I removed the op-amp from the DAC which lowered it a bit, and also wired in a 50k pot between the DAC and amp, but it only goes up and down a little (not sure if it's wired correctly).
If i plug the DAC into my AV amp, then use the pre-outs to my Amp6, everything's fine, but i would prefure not to use my AV amp.
Could someone point me in the right direction please.
Personally I think you'd find stripboard a lot easier to work with. It allows you to do things like this:
http://img90.imageshack.us/img90/6756/dsc06081largeqi4.jpg
Which would probably have been impossible on a pinboard of similar dimensions!
That's my Cmoy amp by the way.
	Which DAC are you using?
You might find some strange things happening if you put the pot between the DAC and the amp, related to impedance matching.Maximum power is transferred from one stage to the next when the output and input impedances match, so using something like a 50k potentiometer could throw the impedance way out of line if the input impedance of the next stage is something much lower or higher.
A buffer might be what you need, or just to put the pot at the earliest possible stage.
I'm using the "Chinese" DAC, the same one as Damian666.
It says you can use a 50k pot in the assembly instructions for the amp, but I'm not sure if I've done it correctly.
