New system drive(s) wanted
Man of Honour
20 Sep 2006
Hi all.
At the end of this month I will have a little bit of money saved for a new OS drive setup. Budget is around £300.
Backup will be taken care off so I don't mind running RAID0.
The sytem drive is to hold Vista Ultimate 64, about 5 games, Office 2007, PS and some other apps. All user data will be stored on my WD 640AAKS drives.
I am very biased toward WD Drives as whenever I've had an issue in the past their RMA procedure has been second to none.
Suggestions please? 2xVelociraptors 150GB in RAID0? One single 300GB version? Or three 74GB versions with a view to adding a fourth all striped? As I said, my OS drive get ghosted every two nights so I'm really not bothered about running a RAID setup with such a high risk. I want the most performance possible for the best price. Required for gaming, PARing, RARing, Burning etc.
I would either wait for the 150Gb Velociraptor, or go for the 300Gb VR. Unless you want RAID, then just Raid the Velociraptors. Depends how much you want to spend.
RAIDed velociraptors would be pretty sweet, would best any SSD for read/write. Dunno how loud they are though if that bothers you.
about Western Digital VelociRaptor 300GB
Not so quick
Reviewed by: ksdp37
If you've got money to spend, wait for the Intel Solid States Drives.
Each apparently offers 240mbs read and 170mbs write (entreprise drives). They'll blow the raptors/veloci raptors away! You'll need 3 - 4 of these drives to match that performance!
Can you imagine the Intel SSD's on a stripe array?
Samsung warrenty puts me off. I'm not bothered about noise as my speakers are nearly always on blasting out tunes or games. How much for the Intel SSD drives?
Depends on the size you need, you could be under budget and still faster than a veloci.
If price per GB is a concern you should either get a lesser SSD like an OCZ or a veloci.
How many GB can I get for £300? And will it be better then two V-Raptors in RAOD0?
I don't care about £ per GB, as long as I can fit my OS, BioShock, BF2, COD4, Office 2007 Enterprise, GRID, PS and a few other progs on and still have headroom I'm happy. No idea how large my C: is atm as I'm away from home and on my Lappy.
