Giganews slow today
7 Jul 2004
Gloucester
Anyone else finding this?
Just did a speed test on speedtest.net which showed 10mb
Trying to download from Giganews & it's going at 500Kbs with 10 connections. I usually get full speed. I've checked all my newsleecher setup & it's normal. Weird :confused:
Not using giganews but i'm using powerusenet
Speeds 50% lower than normal :( using ssl port 563
Yet on speedtests of various kinds i get my usual 10-12meg speeds weird !!!
Using adsl not cable if that makes any difference
Don't giganews have a speed tester on their site?
It might be an indication that your ISP has started throttling your NNTP usage.
Seems lots of people with BE are having the problems but they cant see any probs on their network.
Thats according to BE forums.
Trace route your news server, you may find it's taking an unusual route, or a router taking a long time to respond.
I'm with o2 so might as well class it as be
Think they are starting to cap NNTP ?? (i assume nntp is news etc)
I'm with o2 too and am getting full speed.
No plans i've heard of /re capping/throttling on o2 or Be and I'd be surprised if it got rolled in overnight like that.
so explain how I was getting slow speeds in Durham on Be* and a friend in Liverpool was having exactly the same problem on SKY, I've heard USENET changed some of the details for hi-speed accounts.
So explain how I was getting normal speeds on Be? Constant 2.2+ MB/second.
Usenet is just the name of the newsgroup system in general. Your accounts are controlled by whoever you purchased them from (e.g. Giganews). Plenty of people download constantly on these connections and don't ever get limited (by their newsgroup provider).
It's quite possible that it's not an ISP issue, but clearly there's more to it than you seem to think.
Out of interest, are you using the europe giganews server or the standard one?
