- 28 May 2007
Ignore.
Thanks a lot guys - btw what is the advantage of the 1024mb model? I don't change cards that often and the price difference is not huge. If the 1024mb will give me something extra i'll buy it - but if its a waste of time let me know and ill skip it.
WOW is basically so old now anything plays it.
Even WOTLK with its new shadows its fine at 1920x1200 (beta versions).
Regular wow with Graphics macro to improve them, with AA, at 1920x1200 was 60 FPS on my 8800 GTS 320MB.
QUOTE]
Not quite, a 2.66Ghz Pentium D with a 8800GTX lags like hell in Sunwell, we're talking 7fps, with cpu at 100% load.
On the other hand a 2.66Ghz Core 2 + 7900GTX and Wow rarely drops below 40fps, and is often 100+. Wow needs a balanced machine with both CPU and GPU being "ok".
The Wrath of the Liche king shadows hit performance hard on older cards like the 7900's too.
My post was obviously referring to the GPU side of things, because that is what the OP asked about.
WOW is mostly CPU Dependant, with several addons loaded, it usually comes to around 800 mega bytes (at least, according to CTRL+ALT+DEL)![]()
I agree if he was gonna play those games and no new ones over a decent period of time get a 4850 but if he does start to play newer games in that period its a 4870 all the way.
The fact is he states he does not change cards to often the 4870 has to be the way to go it handles the res very well so it will last him much longer than a 4850 which with its much slower memory may limit him quickly depending on games released which the 4870 will not.
You are not really getting the point a 8800gtx with more memory and bandwidth is starting to struggle a little in graphics intense games at that res and is around the same speed as the 4850. Overclock the memory on the 4850 it still can't get near the bandwidth on the 4870 which overclocks to silly speeds also. The majority will tell you that the 4870 is the much better card for the res and as games get more intense so will the lead the 4870 has over the 4850 so why not get a card that has around 30 percent speed advantage with the memory that will not hold the card back in the near future. I am not in the minority with my views on this. 512 and gddr 3 struggles now and again with some games which the 4870 does not at higr res. I guess what i am saying is for his res the extra money will give him more piece of mind.
