Thnaks for the replies regarding bios. Could you confirm which bios version is recommended to upgrade to? I think 1001 is the latest mentioned.
There was once a time when there was no such Q-Connector.Quick question - I'm moving my board to another machine, but I think I've misplaced the Q-Connector thing. Really useful piece of plastic.... I don't have the board in front of me right now - But without it, can I still connect the case leads for power, reset etc directly to the pins on the motherboard ? I hope so...
This MOBO needs a fair bit of NB volts if you plan on a high FSB OC, ive got 1.7v on mine but its WCooled.Usually the best is the latest 1101 from asus web site, if you are stable & happy with an older one stick with it.
Got one of these recently with a intel 2160 dual core, both for £50+vat & its 3200 stable with reasonable temps on air with an artic pro7 - took me a couple of hours finding the best settings in the bios as it was doing all kinda weird hangs & crashes with budget elixir memory set to auto.
Current core voltage is 1.4, memory 1.9 & n/b needed a bit more.
Just a note regarding 45nm Quad compatabilty on the P5N-E. Despite the manufacturer not officially supporting them, they do work.
Q9450 FULLY WORKING and recognised correctly on my P5N-E running either 1101 or 1201 bios
There are lots of fsb holes where the processor will not post, but I have successfully tested at the following settings.
Stock 1333fsb x8 = 2.67GHz
OC 1500fsb x8 = 3GHz
OC 1550fsb x8 = 3.1GHz
OC 1667fsb x8 = 3.33GHz
I can also get into Vista at 3.46GHz (1730fsb) but it is not stable. Northbridge requires 1.7v for 3.33GHz and over so it gets HOT.
So, try a quad in you old P5N-E (or 650i mobo) before buying a new motherboard.
I have never attempted changing the LDT setting. It is at default (5x). You may just be hitting some of the many fsb black holes this board has.1650fsb is a frequency that has worked well on every 45 and 65nm chip I have tried in my board. Perhaps lower your multi and try that.Just a question here - what setting did you use for LDT Frequency?
I find that if I overclock to an FSB of 1400+ I have to set this to 3x, as even 4x it becomes unstable in windows general use such as hard drive seeks and when I use the graphics card in a game for example, and 5x it doesnt even load windows.
Dont know what this does but I have a feeling its bottlenecking my system's overall bandwidth. Is it true that the LDT frequency should be equal to 1000 and that its that value multiplied by the bus speed?
you will only run 8 PCIe lanes per slot with two gfx cards on a 650i chipset based boards, probably not an ideal setup for two 9800gx2's. running two 9800gx2's is pretty ott and running them on a 650i board is pretty compromising.
