Does anyone else have "clog" effect like the game was leaking into graphics memory - at start game runs smoothly (as much as Crysis can run smoothly I mean) then gradually gets more and more choppy as you progress through next two or three levels to the point where motion blur when you turn around quickly gets really choppy and cut scenes are almost unwatchable. Then if you quit and start again it gets smooth again for some time?
Yes I get that, I had to restart just before the final battle as the end cutscene was very choppy. It was fine after.
As if you would be able to get away with that easy just by getting it through steam
