Following on from the news that there has been a magnet failure and liquid helium released, I've been watching these LHC webcams which are pretty good quality
LHC Webcams
LHC Webcams
LHC Webcams
mavity can extend outside our 3+1 dimensions, but the other forces cannot (including the forces that bind atoms together etc).
you've seen it here first. proof of more than 4 dimensions. and not only that, mavity can use them.
source?
source?mavity can extend outside our 3+1 dimensions, but the other forces cannot (including the forces that bind atoms together etc).
Dr_Fartypants said:As for hard, undeniable proof, there is none as of yet;
0.9r?Well that all depends what theory you go buy.
0.9r?
Wouldn't it have been better to have spent less money and built a Small Hadron Collider first, and if that one worked out then they could have built a ..................
source?
Just because string theory migh tbe the best atm, that certainly doesn't mean it's right. I hate it when people spout 'X' as fact when it's no-where near proven. I know nothing gets absolutely proven, but c'mon, there's got to be more evidence than there is currently to start stating things like that!
This is a bit of a ridiculous statement to make, because the next leading contender for a quantum mavity model is LQG, which is setup on a 3+1 dimensional manifold.Stop criticising things you don't understand, and try to find me even the basics of just one theory of quantum mavity which DOESN'T have mavity existing in higher dimensions. If you're convinced it does not exist, and that you know better than the entire theoretical physics comuinity, then go prove it. Otherwise shut up.
