reading the Paint Renovator info page it says to use SRP after using paint renovator in order to restore the original finish of the paint and finish off to a gloss so looks like both will be needed, not bad as I have srp anyway
reading the Paint Renovator info page it says to use SRP after using paint renovator in order to restore the original finish of the paint and finish off to a gloss so looks like both will be needed, not bad as I have srp anyway![]()
Autoglym said:We recommend you always try Autoglym Super Resin Polish first as it may rectify your problem without undue paint removal.
ScoobyDoo69 said he has some spare titanium silver Dr Colorchip if you want it.![]()
Why did Fox not want it? is it not very good ?
Thanks Fox for the touch up pen offer on Saturday, I’ll buy a pen from BMW as I don’t want to use up all your paint as I’m sure I may well need it for light scratches or stone chips again in the future.
Thats the thing, he does want it :/
[TW]Fox;12562475 said:MeHad I been the OP in this thread it would be full of people taking the **** and telling me to get a life and that it was just a scratch - the dent I posted about once was bigger than that ffs
Yes, but this scratch won't disappear if you leave it.
