Below is a screenshot of an Intel Q9550 on an Asus P5Q Deluxe (BIOS 0803), cooling is by a Thermalright Ultra-120 Extreme with Scythe S-Flex 20mm 1600rpm fan, PC Case, is a Li Lian PC-60 with 4 x 80mm fans + Antec 80mm fan onto ram and nb, even at stock clocks (2.83GHz) the temps are only 2-3C lower (ambient room temp 22-24c). Heatsink has already been re-seated, am using Artic Silver 5 paste.
I reckon that these temps are a bit on the high side, would that be a correct conclusion?
What temp does a Q9550 throttle at?
In this shot Prime95 had been running about 21mins with no errors.
