do not be using either of these regularly
If your the sort of person to clean your wheels once every 2 months, or only once you've forgotten what colour they used to be you'll probably be ok
But these (Wonder Wheels and Megs Hot Rims) are both very strong cleaners. If your going to be cleaning every week etc. then get something much milder as you will eat away your lacquer.
ive got some carplan wonderwheels and also some virosol, rate them both about equal tbh! I got 3 big bottles of virosol from costco for £8, they charge £9 for one of them from halfrauds!
Halfords sell Virosol now?? Awesome!
I need
a: A Costco card
b: A Costco to open in the South
c: Profit???
I use Meguiar's Hot Wheels and whilst it's good, DO NOT leave for more than 10 seconds
fs i meant the carplan stuff! Edit on its way
there are costcos in the south?
if you have sensitive alloys or painted calipers avoid anything that's extremely acid/alkaline, e.g. wonder wheels, virosol, hot wheels, the list goes on. If it smells acidic then I wouldn't go near it.
Bilberry is as good as it gets and also safe. If they're really dirty you just use a higher concentration, anything left then 2 minutes with a claybar and it's gone
p.s. I'm sure it's virosol that's rebranded toilet cleaner
Wonder Wheels has never proved to be a problem on my Painted Calipers but then again i'm not Hamfisted with the stuff.
Going to check out this Bilberry product however, sounds good.
why would virosol be alkaline when its citrus based ?
surprising, maybe it's not citrus based then and just has an added "orangey" smell![]()
