Does "Advanced performance" make any difference?
28 Jun 2005
Behind you
Hi,
Does enabling the advanced performance under the disk drive properies in Vista make a lot of difference to load times / virus scan times ect?
Thanks
Hi,
Thanks
Yes but do not do on a Lappy (due to battery could run out and you loose data).
I posted some info here long ago to get HDD bit faster.
I cant remember all but Kill the Low Disk Warning and some old DOS thingy too if you do not need.
Its here to SEACH for.
http://www.vistax64.com/tutorials/59886-hard-drive-speed-boosts.html?filter[11]=Performance%20Maintenance
http://www.vistax64.com/tutorials/67600-low-disk-space-warning-vista.html
