Where?
WD RE3 Features:
* StableTrac™ - The motor shaft is secured at both ends to reduce system-induced vibration and stabilize platters for accurate tracking during read and write operations. Visit the Web site at
http://www.wdc.com/global/flash/inde...ily=stabletrac to see StableTrac in action.
* Dual processor - Twice the processing power that results in a 20 percent performance improvement over the previous generation.
* RAFF™ technology - Resulting in up to 60 percent performance improvement over previous generation drives, WD's fourth-generation RAFF technology includes sophisticated electronics to monitor the drive and correct both linear and rotational vibration simultaneously in real time for maximum performance in high vibration environments.
* IntelliSeek™ technology - Calculates optimum seek speeds to lower power consumption, noise, and vibration in active seek modes without degrading performance.
* Multi-axis shock sensor - An additional third sensor has been added to RE3 models to detect automatically the subtlest shock events and to compensate to protect the data.
* RAID-specific, Time-Limited Error Recovery (TLER) - Prevents drive fallout caused by the extended hard drive error-recovery processes common to desktop drives.
* Third-generation dynamic fly height - With this next generation dynamic fly height technology, each read-write head's fly height is adjusted in real time for optimum reliability.
* Thermal extended burn-in test - Extended burn-in testing with thermal cycling added to ensure only the most robust drives are produced as RAID Edition.
* NoTouch™ ramp load technology - The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
