I've just had to RMA my Ballistix Tracer PC8500 bought last January.
I had it set to 2.2v on my IP35 Pro as recommended by Overclockers and until recently Crucial themselves.
However if you check out the Crucial website
http://www.crucial.com/uk/store/partspecs.aspx?IMODULE=BL12864AL106A
the recommended voltage for this and other Ballistix modules is now 2.0v.
I don't know if this revision should apply to all Ballistix or just the most recent production run. Maybe someone can give a definitive answer to this.
In the meantime I've just dropped the voltage on the new Ballistix I bought today to keep my system running while OcUK test the faulty ones.
Cheers,
Tag
Cheers,
Tag
