start clocking that CPU mate - edit just seen above.
If your cpu speed is 3200 (3.2 ghz) i would lower the cpu multiplier to 8 and up the fsb to 400, then just change the memory divider so its as close to 1066 without going over, but make sure your giving your ram and cpu the correct voltages.
ok i followed the above that takes me to 3.6ghz which would be nice whether it would hold in prime i give it a bash anyway lol
im a bit confused over the ram settings, 801mhz,961mhz,1280mhz which one do i go choose![]()
