i've built my first pc pics included
If u haven't finished clocking ya CPU then make sure you don't go beyond the 1066 native speed of your ram, cos if you get a crash/prime die you won;t know if it was the RAM or the CPU overclock that killed it.
With regards to the vcore, keep it as it is, and run small ffts for 30 mins or so, if it fails go and up the vcore to 1.31v and try again.
well i wanted to get to 3.4 if possiable whats the best route to finish off my overclock to 3.4ghz,i have ran prime for a good hour temos at 54max on full load
Wow that is most excellent!! Thanks for posting those photos. Im thinking of building my next PC but Im still apprehensive as i know nothing about the subject ,specially when it comes to selecting components. But your thread has now encouraged me further to think about it!
Is that cooler from a Toyota Land Cruiser? I like it!
Ok well to get to 3.4GHz, you do FSBx8 (8 is your current multiplier). So change ya FSB to 426 (426x8=3408) and that will give you your 3.4GHz clock.
However, I wouldn't jump straight to that, cos you will get confused at whats killing it. So go to 3.3GHz first, then rn small FFTs and if it lasts, up it to 3.4GHz then run small ffts again. At some point in that increase you WILL need to up ya vcore, so up that a notch everytime it fails.
im in the same boat didnt have a clue how to build nor overclock hence the million questions without these guys i would be stuck or worse blow up the pc never be affraid to ask like me i tend to learn better when people type it out makes it easier, all i can say is go for it:D
ok mate i be working on that now then let you know my progress:D
i have change it from 333 to 400 and has given me 1066ghz option what you want me to do now, i put 1.3v for cpu as my vid is 1.3 when i first started o/c should i increase it if so what should i type in??
leave it at 1066 now run prime 95 and see if runs ok if not you will need to up the cpu voltage till its stable - should need to be around 1.4 - 1.425v depends on the chip.
ok so far its stable at 3.2ghz ran prime small fft and blend no problems left it running all day whilst at work temps 57c max im set at
cpu ratio frequency 08.0
fsb frequency 400
pcie frequency 100
fsb strap to north bridge 400mhz
dram frequency ddr2-1066mhz
dram frequency manual
cas latency 5 dram clocks
dram ras to cas delay 5dram clocks
dram precharge 5dram clocks
dram ras active to precha 15 dram clocks
rest on auto
cpu voltage 1.30
dram voltage 2.10
rest on auto
cpu spread spectrum disabled
pcie spread spectrum disabled
advanced
cpu ratio setting 08.0
cie support disabled
max cpuid value limit disabled
intel virtualiztion tech enabled
cpu tm function enabled
excute disable bit enabled
think i have set everything correct,should i go to 3.6ghz whats the next best settings to add?
