Which Brand of HDD?
5 Mar 2003
Nottingham
Been ages since I've got a new hdd. A few years ago Hitatchi were the ones to get and thus I have 2 x 160gb of them. This seems to be peanuts now so I'm looking at getting 2 x 500gb... so what are the best for this size (will look up to 750gb too!).
Don't want to buy one 1tb/1.5tb as I duplicate certain files across both drives.
Cheers :)
Im liking WD, however they are pricy.
Samsungs are the next best thing (very similar speed wise) and the 320/640 are the sizes to get.
2x 640Gb Samsung F1s would do you if that is sufficient size wise, otherwise look at the 1tb F1s for very little more.
Cheers for the feedback fellas. Think I'm liking the look of the Samsungs after looking at the prices etc. Other than the space, will I notice much performance difference between the 500gb and 750gb Samsung models - the former has 16mb cache, the second has 32mb.
I'd stick with WD, last 10 years we use on average 20 HDs a week and WD are the most reliable.
Hitachi can take a hike after the deathstar click-of-death fiasco and every Maxtor 120GB disk we ever sent out (100s) failed within 2yrs.
Seagate have been ok, but had a fair few dead from new... so it's WD all the way for me.
Not tried Samsung, but not gonna risk it... you only find out reliability 2yrs down the line and so far (touch wood) WD have not been failing in any qty over last 10yrs.
WD640AAKS is a nice quick drive with new 320GB platters AFAIK...
i'd like to echo what Flukester has said..
we don't use as many drives in my work, but my 'dead drive' pile has 1x wd in it and about 15x maxtors roughly the same amount of drives were bought of both makes
i've only seen one dead samsung personally, i have about 9 of them
Samsungs very good, very reliable, excpetionally quiet and very good performance wise. I've got the 1Tb F1 and its a stormer! 334 Gb per platter which I think is the highest so far?
Samsung reliable :confused:
lol
They have one of the worse if not the worse reliability records of all hd manufactures!!
WD
Seagate
Would never buy a sammy drive tbh, restoring 100's of GB's of data aint fun :p
My faulty HD tally compounds this opinion as faulty Samsung HD's are over 2x as many (38 units) as the next manufacture (IBM/Hitachi) (18 Units)
Ok down to the last two:
Western Digital Caviar Blue 640GB SATA-II 16MB Cache - OEM (WD6400AAKS) - £50
Western Digital Caviar Black 640GB SATA-II 32MB Cache - OEM (WD6401AALS) - £57
I assume they are the same underlying drive - just one has the extra 16mb cache?
I am not sure which is faster The AAKS has 2x 320gb platters am not sure about the blacks i want to know too was about to buy a 640 gig aaks
lol
WD
Seagate
Maybe you got a bad batch? :p
My friend who currently works at a large manchester reseller always tells me that they have less samsung returns than any other, seems hitachi are top of the duffers list with maxtor.
He says samsung/wd/seagate are the most reliable in that order from his experiance in the returns dept.
Personally i have 8 samsung drives in my machines and not had a single problem so far *touch wood*
Then again ive used countless maxtors over the years in my personal machines and never had one die.. maybe im lucky! the only drive ive had die on me was an old IBM deathstar ;)
I've got a 320GB Samsung SATA2 drive in my rig & its the bees, Without a doubt the most silent Hard Drive i have ever owned!
Liam
Specifications1 1 TB 750 GB 640 GB 500 GB
Heads/disks 6/3 5/3 4/2 4/2
Not terribly clear, but as long as disks = platters, then the 640GB does have 2 platters :)
Thanks for everyones help. I've just purchased the Black 640GB. Will see how that goes and if happy will purchase the second one :)
I've been looking at getting one of these too but I've not seen a review anywhere!
How have you got on with your new HD? Have you had a chance to give it a test?
I'd still get for the sake of an extra £7 the blacks for the 5 year warranty and they have tech to make them quieter and use less power which the blue doesn't.
