electrical wire - quick question
29 Jul 2003
hi guys
got 1.5mm twin and earth cable, rating at 20Amps
how many wattages can this cable can safely hold?
it will supply electrical to 3 x 9W light and shower fan/light
thanks
hi guys
thanks
running 18w of lighting and 100w (ish) of fan won't be a problem for 1.5mm cable.
Why? There's no law that says you can't do it yourself ;)
What the OP is proposing is allowable under current building regs., but anything much more involved must be done by a certified electrician. My understanding is that a spur off an existing circuit is allowable.
But see below:
Article: Electrical Regulation Changes Hurts the DIY Enthusiast
From 1 January 2005 all electrical work in dwellings will need to comply with Part P requirements and be carried out by persons who are competent to do the work.
Small jobs such as replacing a socket-outlet or a light switch on an existing circuit will not need to be notified to a building control body (although there are some exceptions for high risk areas such as kitchens and bathrooms).
All work that involves adding a new circuit to a dwelling will need to be either notified to building control, who will then inspect the work, or carried out, by a competent person who is registered with a Part P Self-Certification Scheme.
From http://www.buildingservicesguide.com/Articles/Article_4_15.asp
Spurring off an existing circuit is allowed.
New builds (including extensions, conversions etc) must have a "Part P" and Electrical Safety documentation.
Simply changing a light fitting, or spurring off to add a secondary light fitting in an existing building is fine.
There seems to be some wrong information in this thread... Adding extra points in a bathroom is *not* exempt from notificaton as it is in other rooms, therefore the work the OP plans to carry out is a notifiable service under part P of the Building regs
....sorry! :(
errrr, verbal's bro/flatmate just posted as him by mistake
nothing to see here
