- 16 Oct 2008
OK I know were far from cutting edge here, but I'd like some advice on what cpu cooler you would go for on an old Asus P4P800 Deluxe (865PE Chipset I think) and a Northwood P4 3Ghz (may upgrade to 3.4 if i find a cheap one).
My Case is an Antec SX1030
as you can see i have a fair bit of room inside (once i tidy the damm thing up) I have bought some quiet 80mm fans for the case itself but would like to change the stock Intel fan with something a bit quieter, right now I'm not going to bother with O/C with it.
So I'd welcome any advice you cam give, except buy a new rig
All1
All1
