Not indicating which core also have checkpoint set @ 15 mins but it rarely appears in the FahMon log08:49:52] Folding@Home GPU Core - Beta
[08:49:52] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[08:49:52]
[08:49:52] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:49:52] Build host: amoeba
[08:49:52] Board Type: Nvidia
[08:49:52] Core :
version not change to 1.16 either11:54:45] Decompressed FahCore_11.exe (1822720 bytes) successfully
[11:54:50] + Core successfully engaged
[11:54:56]
[11:54:56] + Processing work unit
[11:54:56] Core required: FahCore_11.exe
[11:54:56] Core found.
[11:54:56] Working on queue slot 09 [October 21 11:54:56 UTC]
[11:54:56] + Working ...
[11:54:57]
[11:54:57] *------------------------------*
[11:54:57] Folding@Home GPU Core - Beta
[11:54:57] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[11:54:57]
[11:54:57] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:54:57] Build host: amoeba
[11:54:57] Board Type: Nvidia
[11:54:57] Core :
The current Nvidia driver are CUDA drivers so there's nothing else to install (unless I've really misunderstood things!).Noob question - do I install CUDA drivers on their own or plus the usual geforce one. Does it matter what order I install if I have to use both.
currently getting
Not indicating which core also have checkpoint set @ 15 mins but it rarely appears in the FahMon log![]()
Just had another EEU.
Still new to Vista Mr Snapshot so haven't been brave enough to tamper with the shortcut, maybe this weekend as I don't want to stop it running on start up. I know I have to put it in the start up folder.
Amazing what you find when you read to the bottom of the screen. Done it & it seems to be working, however FAH site & EOC saying no WU since 2-37 UTC. Lost the log on restart but I'm sure I should've had another 2 since then
I've only just found out about 1.17 but running with 1.15. Just had an EEU @ 80%
I found a reboot fixed it for me.Im on 1.15 and seem to be getting EEU all the time.
Would like to get a more upto date core if i could as it might help me out.
