The All New Desktop Thread, Images No Larger Than 800x600
Unzip the zipped folder it downloads in then drag the 'StackDocklet 15-01-2008'(if you downloaded the same version as me) folder to:
C:\Program Files (x86)\RocketDock\Docklets
once its there restart your rocketdock, right click > add item > stack docklet.
hope that helped! it was quite hard to explain for some reason!
Yup thanks it worked, now how do you have your folders displayed like you have using rocketdock?
as in how does he have the folders coming out? that's using stack docklet
or do you mean he has 2 docks? are you talking about the left hand side or bottom dock?
Right click the icon, icon settings, then set mode to 'fan'. In automatic it uses fan for a folder with a few items, and a grid if there are many items in the folder you are using the stack on.
I think he's stuck at adding the docklet to the dock, that info was even in that aqua soft thread link I got from someone on this board lol
Right click on the dock and goto Add Item > Stack Docklet
An new square icon with a downward pointing arrow should appear on your dock. That is the Stacks docklet. Rick click on this icon and go to Icon Settings as mentioned in the posts before this to set up the directory, icon and fly out menu type (grid, fan or auto).
Thanks
when Pidgin minimises, it goes to the System Tray. Clicking on Pidgin on ObjectDock tries to open it again, rather than maximise it, and just produces an error.
