FARCRY 2 --- Officially , official of official threads! ---
Well, it's more of a "work undone" issue - you spend an hour scouting large camp, stealth killing guards, disabling vehicles so they can't chase you or escape their death and then setting fire around the lot using gas cans and molotovs while withdrawing to safety just to discover that once you move round the corner and back everything is restored, not only guards and camp staff, but gone are also effects of explosions and any traces of fire you set 5 minutes earlier. 6 months of demos how they took trip to africa, made realistic environment with weather patterns, directional wind gusts, sunrise and sunset in real time, and this and that, and birds migrate and foliage rots and mushrooms grow. And ****** enemies rebuild camp in under 60 seconds from restoring save.
Had a few days off. completed the game.
Meh. It's o if you havbe nothing else to play. quite tedious.
The Ending was short - must be more than one as you get to choos various different paths twoards the end.
Spoiler:
I picked ub the Briefcase at the end & once handed over i saw a small explosion and that's it - game over.
only one problem though, i've installed it twice. the first time avast picked up this, mastroschka_launcher and the descirtion says trogan-gen. so i uninstalled it and on the second install it picked up the same thing, both times near the end of the installation.
anyone else had this and is it harmful?
I had exactly the same with mine using avast also. I just told avast to ignore it as i presumed it was something to do with the security crap bundled with the install. I'm guessing it should be fine...had no problems so far.
I also had this with AVG, I ignored and then ran an AVG update and it seemed happy with the file after this.
I’ve had it before with stuff like this, I’ve had it with WoW following updates and also had it with Crysis.
LOL i had this aswell =] but it seems fine now, hope its not "spyware" like in BF2142
I cant actually wait to finish work and go home and fire up Far Cry 2 - Thats how good it is to me!
I havnt had the urgency to play a game like that since GTA: San Andreas!
\checks time :(
Yeah, was suprised when I looked at my stats last night and was up to 7 hours gameplay and only 12% in.
I love that no enemy encounter plays out the same. Though I have not had any major "wow that was so cool" moments as yet, like some. Though I have used fire to get effect sometimes :)
Also, now that I noticed there is a bus in pala as well, I use them a bit - when I looked on the low scale map it only displayed 4 in the corners so using buses seemed pointless as would have had to travel so far to get to one. Not too bad with one located in the center.
