Which Collinite version should I get?
What colour is your car?
476S is fine for any car but 915 is more suited to darker coloured cars, especially with metallic paint.
Although the Collinite waxes have frankly awesome longevity which is good for winter, the finish is crap compared to other waxes. It still gives a wet looking shine but if you have metallic paint, the sparkle in it just doesn't "pop" at all. I previously had Chemical Guys 53 and XXX on my car and the way they brought out the colour of the paint was stunning. When I put Collinite on about a month ago, the colour looks very flat in comparison.
I'm sticking with Collinite 915 over the winter though. It's much more suited to the weather.
Its Black and I want shiney![]()
Does longevity bother you at all? What is your budget?
I highly recommend Chemical Guys Petes 53 Carnauba. It's designed specifically for darker cars and it certainly shows. I seen a whole new side of my paintwork when I applied it to my car, it absolutely blew me away! It gives significantly better results than any of the Collinite range in this respect.
It'll last about a month before it needs another coat so as long as you dont mind doing it once a month it sounds like it will suit you fine. It lasts longer than most other waxes for the same price, apart from the Collinites of course. A tub should last you for at least a year if you apply once a month.
Here it is - http://www.cleanyourcar.co.uk/wax/chemical-guys-pete-39-s-53-paste-wax/prod_337.html
I highly recommend that company too, their customer service is second to none.
Great, thanks. How do you apply and what do you use to remove. How long do you leave it too? I can handle once a month.
