How do you check the antifreeze concentration?
I normally make sure it tastes sweet, but you can get tester things am sure.
[TW]Fox;12795701 said:He did a 'quick fix' apparently. What sort of 'quick fix' involves draining all the coolant out?
). Anti freeze is only needed in countries that have climates which seasonally go below 0c
He didn't say it had no coolant, he said it had no antifreeze. You'd notice if it didn't have any coolant, but having no anti freeze, just water in is a bit harder to spot.
Coolant change
ho ho ho
Lol!
How many remaining brain cells did you kill then![]()
Aren't there two main types of anti-freeze?
IIRC They shouldn't be mixed.
not really, antifreeze has an obvious colour. Red, blue, or green, if it's brown then its full of rusty crap, flush it and replace the radiator.
[TW]Fox;12795682 said:Most people use the terms interchangably. I doubt this 'mate' glanced at the expansion tank and said 'I say old bean, the concentration of water to antifreeze looks a bit awry! Best get that sorted pronto'
Perhaps he actually tested it using a hydrometer?Remember kids, not only do you need anti-freeze to stop your cooling system freezing but it also stops your engine corroding!
Surely this isnt the correct way todo it?
