- 29 Oct 2008
I've decided on getting a 260 - I wanted to stick with Nvidia, and I was going to buy Far Cry 2 anyway, so that made that card the clincher. However, what's the difference between the 260s on overclockers? Can anyone point out a particular model I should go for? At the minute I'm looking at this one:
http://www.overclockers.co.uk/showp...2-BG&groupid=701&catid=56&subcat=927&name=BFG GeForce GTX 260 OC 896MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
A) It's the cheapest and B) it says it's overclocked. But what I don't get, is if it's overclocked why is it cheaper? Shouldn't it be more expensive because you don't have to touch it straight out of the box? There's also this one that's 'core overclocked' but it's £40 more expensive.
http://www.overclockers.co.uk/showp...-EA&groupid=701&catid=56&subcat=927&name=EVGA GeForce GTX 260 "Core 216 Superclocked" 896MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
I want the 260 that'll perform the best, not necessarily the one that will be cheapest (but the 2nd 260 would have to be quite significantly better than the 211 one to warrant a purchase). Help a nub out please, ta.
