- 5 Dec 2004
- Horsham, UK
There were several reasons why I personally chose the NEC over the HP.
The first was the text clarity problem that affected several people with the HP. That's really important to me and there were various potential reasons put forward including the wide-gamut and the organisation of the sub-pixels in the IPS panel - both fundamental to the HP. There were a couple of other, lesser problems that also made me feel uneasy.
Secondly the wide-gamut put me off - I'd like to see colours as they were intended to be, and until the world in general adopts wide-gamut I don't see that happening without lots of fiddling selecting and swapping between applications. I'm not a great photographer, but it's useful having the monitor display what I want it to in the comparatively secure knowledge that the end product will be printed as I saw it on my screen. I want something that 'just works' as much as possible.
Thirdly the looks. This monitor is likely to end up in as part of a 'home entertainment' hub and as such the HP's WAF is a very distant second to the NEC. The built-in speakers will also be handy when the daughter is playing on her WII and doesn't want/need the full AV receiver setup turned on.
Next the input lag on the NEC is significantly better than the HP. I don't have the time to play games every day, but when I do I don't want anything ruining my experience.
MVA vs IPS. I've compared the relative merits of the idealised panels types and I'm happy with the compromises I would have to make choosing MVA over an IPS panel - such as viewing angle.
As I mentioned in the HP thread, this boiled down to a decision between the HP that has been reported to have problems that would be show-stoppers for me and wouldn't be as suitable in the environment in which it may sit, and the NEC which had negligible feedback but was from a quality vendor that I've used before, could be used anywhere in the house and was much less likely to suffer from any show-stoppers inherent to the technology used. Price was a factor, but not a show-stopping issue - and became less with the 6% off.
So having lived with the monitor for a week or so, am I happy?
You bet I am. Apart from the stuck sub-pixel, which I can't actually see at my typical viewing distance, there is nothing about this monitor that would make me contemplate sending it back. As far as I'm concerned, I have absolutely the best monitor available to suit my needs, and for that I'm willing to pay the extra £130 (mine cost £586 delivered vs £458 for the HP) to avoid compromises.
Of course, all this is my very humble opinion - but in my very humble opinion, my very humble opinion is the right one!
