Share Folders between laptops
17 Dec 2003
Peterborough
Need a little help.
We have 2 laptops here at home and I wish to transfer my music files from one to the other.
How easy is it to share the music so I can copy it on to this laptop?
Using a cross-over cable (cheap as chips ;p), you will be able to create a very small LAN. From here, you can share folders from one laptop to another.
It is easy, create a folder on 1 laptop. Right click and select the sharing options, share the folder and give it a name.
What os are you using?
yup
go to the system properties window to find out the 'computername' for both machines, rename them to something easier if you want
like 'allen' and 'janice' (assuming the other laptop is owned by janice :D)
on allen, right click music folder, click sharing (might be properties, then sharing tab), click ok etc and choose whatever options
then on janice, do start, run (winkey + r) and type..
\\allen
this will now show all the shared folders/printers on allen, depending how it's setup it may ask for a username, if so, then type the username and password that allen uses to access his laptop.
simple & built in :)
We are both on Vista. You can call her Janice, I think I might too now :D
Thanks for your help gents, will get on that tonight.
worth noting..
do it on both (the folder share), and it should sort out windows firewall for you
if you've got a 3rd party firewall, then it'll ask for confirmation etc..
