Core i7 is here!
13 Mar 2004
Norwich
Well DHL just delivered after driving past a few times and me having to go stand in the road and flag him down.
At least he knows now for next time.
Anyway few pics and then I am off out to the football.
Will be stuck using the stock cooler until I can get the TRUE 1366 kit.
Anyone else get theirs yet?
Ok, most folk would say core I7 is out of their range, but what about a comp to see how little we can actually get this system for?
For example you can get 3x1GB DDR3 at 1333MHZ ballistix for <120 at first glance, £85 basic crucual say...
3*2GB DDR3 at 1333mhz for ~150
all this simply by buying the sticks rather than the packs.
Motherboard now:-
http://http://www.overclockers.co.uk/showproduct.php?prodid=MB-156-GI&groupid=701&catid=5&subcat=1283&name=Gigabyte%20EX58-DS4%20Intel%20X58%20(Socket%201366)%20PCI-Express%20DDR3%20Motherboard £223 inc vat
and processor
http://www.overclockers.co.uk/showproduct.php?prodid=CP-252-IN&groupid=701&catid=6&subcat=1272&name=Intel%20Core%20i7%20920%202.66Ghz%20(Nehalem)%20(Socket%20LGA1366)%20-%20Retail so 282 inc vat
giving us a partially upgraded i7 rigg with 6gb for ~665 or 3gb for 600
I'm looking to upgrade, as you can see from my spec below, but not sure whether to do so now, or early new year...
Hi there
Glad DHL got to you OK and please report back how you find I7, I was very impressed with the sample gear I have. :)
Next week we have stocks of the Foxconn, Gigabyte, EVGA boards arriving along with a much wider range of memory from Corsair, OCZ and G.Skill so got a feeling this will start catching on rather quick.
What will impress you is the memory bandwidth on I7 its just AWSOME! :)
Congrats on your new toys.
I'm so jelous! Can't wait to see your comments once you get it all together.
I'm thinking the VAT number might be comming out if I'll be let use it to save a few bob.
HI there
I've done some testing today on the Asus P6T Deluxe to see what our own Triple Channel kits can do.
I am please with the following results:-
1600MHz CL8-8-8-16-1T with just 1.6v (No airflow over memory)
1866MHz CL9-9-9-24-2T with just 1.7v (No airflow over memory)
What this means is that the OcUK kits will run quite happily upto 1800MHz with voltage remaining around the 1.65v region pretty much making these the quickest kits available for Intel Core I7 platforms.
The kits do come with Corsair Dominator fans and for those who are happy to push the voltage up I have had these past 2000MHz with 2.0v going through them and yes my CPU still lives.
OcUK Cellshock 6GB PC3-15000C8 Blue Edition 1866MHz (6x1GB) Triple Channel DDR3
This is the top of the line CellShock memory and is targeted at enthusiasts and high end gamers. These memory Kits are based on very best chips, which enables it to run at notably higher speeds or more aggressive timings than its official specification. The 1866 kits have been tested specifically on the new Intel X58 Chipset achieving memory speeds beyond 1900 MHz with 999 timings and 1800 MHz with 888 timings. This additional overclocking headroom enables users to push their memory and their cpu and mainboards to the limit, achieving new performance heights. While working closely with enthusiasts, hardware experts, mainboard manufacturers and reviewers around the world, we came to the conclusion that the fastest possible System configuration that can be achieved is an Northbridge FSB of 4000Mhz with a memory speed pushing past 2000Mhz with 9-9-9 timings. This configuration is possible with Intel Extreme Core i7 Processors with moderate voltage levels, which are only recommended for short periods. The 1866 Kits are equipped with our well known massive Aluminium Heatspreaders, this time in a beautiful metallic-blue and silver combination, and instead of thick thermal pads thermal grease is used to ensure optimum cooling. This 6GB Kit is approved and pre-tested by OcUK and is compatible with Asus P6T Deluxe (6GB Configuration), all kits are pre-tested at OcUK for Tri-DDR compatibility with Intel and Asus mainboards. We recommend you run these kits at speeds of 1600-1800MHz with below 1.7v for 24/7 running to prevent damage to your I7 processor. In our own testing we found 1600MHz with timings of 8-8-8-20-1T to be stable with just 1.60-1.65v in the Asus P6T mainboards. Running 1800MHz between 1.65-1.75 voltage is also possible with 9-9-9-24-2T timngs. High speeds and more aggressive timings does require going past 1.8v which is not recommended for 24/7 running.
- 6GB (6x1GB)
- 1600MHz CL8-8-8-20-1T @ 1.6-1.65v (Within Intel Guidelines for voltage)
- 1800MHz CL9-9-9-24-2T @ 1.65-1.75v (Within Intel Guidelines for voltage)
- 1800MHz CL8-8-8-20-2T @ 1.75-1.85v (Above Intels recommended voltage)
- 2000MHz CL9-9-9-24-2T @ 1.90-2.0v+ (High voltage could damage CPU)
- 8 Layer PCB
- 240 pin, Non-ECC, Un-buffered DIMM
- Retail Package
- 5 Year Warranty
- Not compatible with Intel Smackover X58 Mainboard
- Compatible ONLY with Intel X58 mainboards with 6 DDR3 Slots
- Supplied with Corsair Dominator Airflow Fan
Price: £399.99ex VAT (£469.99 inc VAT)
BUY NOW!
Anyone who was not so impressed with current memory offerings now have an alternative if your seeking the ultimate in bandwidth and performance. :)
Yup Intel have gone back to their bad old ways of over charging for their products(P4 days)
HI there
Nope not at all, its exchange rate and fact the product is new.
If exchange rate was at what it was at 3 months ago these would be in the £550-£599 +VAT region, a good £250 cheaper and thats all down to exchange rates, not Intel or anyone else.
So the general consensus is to wait until the new year with these then? Instead of upgrading to a Q6600/Q9550 from a Opty 170, 2GB RAM.
