20 Nov 2008 at 12:55 #1 dvdbunny dvdbunny Permabanned Joined 20 Dec 2004 Posts 1,122 As title Can't seem to locate it Many thanks in advance
20 Nov 2008 at 13:07 #2 Nanobot Nanobot Associate Joined 18 Sep 2008 Posts 985 C:\Documents and Settings\Username\Local Settings\Temp
20 Nov 2008 at 13:10 #3 --Mike-- --Mike-- Associate Joined 10 Aug 2006 Posts 804 Location Northampton The Local Settings folder is a hidden folder, so you'll need to change your settings in Explorer to view hidden files.
20 Nov 2008 at 13:12 #4 Snakedoctor Snakedoctor Soldato Joined 13 Sep 2007 Posts 3,951 start then run, then enter %temp%
20 Nov 2008 at 13:20 #5 bledd bledd Don Joined 21 Oct 2002 Posts 46,861 Location Parts Unknown Snakedoctor said: start then run, then enter %temp% Click to expand...
20 Nov 2008 at 14:59 #6 dvdbunny dvdbunny Permabanned OP Joined 20 Dec 2004 Posts 1,122 Many thanks for your replies I found it now, can i delete everything in that temp or is it not safe? I have removed some files from common files found in program files Is there any other folders I should be checking to see if anything needs deleting?
20 Nov 2008 at 15:10 #7 bledd bledd Don Joined 21 Oct 2002 Posts 46,861 Location Parts Unknown just format your pc, like i said in your other thread
20 Nov 2008 at 15:15 #8 GingerNinja1989 GingerNinja1989 Associate Joined 6 Dec 2007 Posts 2,103 In theory, everything in the Temp folder is safe to delete, but then again some programs etc. don't seem to clean up after themselves.
