New Computer - Random Colour Screen Freezing
27 Oct 2008
Hi there just built a new PC and experiancing some problems
I have a quadcore extreme qx6850
Corsair 4GB (2x2GB) DDR2 1066MHz/PC2-8500 XMS2 Dominator ( 4 sticks)
2x Samsung SpinPoint F1 HD103UJ 1TB Hard Drive SATAII
XFX GTX260 XXX Edition 896MB DDR3
Coolermaster HAF 932 Full Tower Case
a Zallaman CPU cooler.
XFX nForce 780i SLI Socket 775 8 channel audio ATX Motherboard
Im running Windows Vista Sp1 64bit
Ok the problem is when ever i try and do any intensive stuff such as playing a game or something that uses a lot of memory .. the PC's mouse starts to freeze and then suddenly i get a random colour screen ...changes the colour all the time .
then i have to reset as the PC has totally Crashed. the Board them gives off a beep for a second and resets its self again ...
Any one else experiance this problem before ? If so what was it
thank you
a 750w jeantech thing , i had to buy it from pcworld lol !
very nice power supply unit though and wasnt cheap
the only reason i think its a heat problem as its when its under load
so either the GPU is overheating or i possibly didnt put enough thermal compound on the CPU maybe ?
a 750w jeantech thing , i had to buy it from ******* lol !
remove shop name(you don't want banning already), i had the same sort of problems and turned out bieng the video ram i had to RMA the card
had a poke around
turns out the Power supply fan wasnt turning on ! near enough burned me bloody fingers a £80 powersupply going wrong lol.. my £4 jobby lasted
thank you for your help.
