Wait til raiding, the mage will destroy the palla at DPS.
Retri was designed as a PVP spec... they run around in Plate - takes no dmg..
I was doing UK last night, and was pulling as many mobs as i could, and just AoEing them down. But look at your gear.... I'm running around in 5/8 t6... I will be using most of my gear into Naxx and heroics. All the instances are tuned for leveling, so your be running around in greens and blues... not t5/6..
You really really need to think about that before slagging off the game.
Actually I'm running around in 4 T6 and 4 S3 with cats edge, so yeah i can say this game is stupidly easy in that respect.
My mage is in Full S3.
And tbh mate, if you and other guilds in such a short period of time clear all the raiding content, then either its not been tuned properly or they are dedicating this expansion to casuals.
You cant say "it was the same in TBC" because when tbc launched you had the attunement quests that at least weeded out the people who where not "raid" worthy, so instead of having the annoying attunement quests, they just nerfed the instances so every noob with questhelper can raid.
