If you search my posts in this thread I posted a fix for the sound-loop crashing issue, although in the full version the problem doesn't occur for me, try it.
Thanks. Alas, I've already tried that (the full game even has the option to disable/enable muti-core use in the video options). Might of stopped the out-and-out locks ups that required a hard-reset, but it's still pausing now and then (sound looping, followed by a black screen, then painfully getting back into the action)Just had it crash on my while loading too, required Ctrl+Alt+Del'ing.
81.19.221.10:30000
89.145.98.10:27025
87.194.121.175:27044
217.163.28.54:27015
found some servers that allow more then 4/8 max playersgonna test them now
You can start your your own game on any map and chapter and just wait for the lobby to fill up. Using the browser is the only definite way to get to an exact one in progress though.
Thanks mate, good to know.
Cheers to Prune, Oddw1re and Buckz for a class game of Death Toll this evening, was a lot of fun![]()
Where are all the extra guns? They are the same ones that are in the demo.
And does anyone know the command to reduce the crosshairs size? I want to do head shots not spray shots! lol
where are the screenshots saved if you take them using printscreen? i cant find them![]()
Early days, give them a chance.![]()
