which way is north?
fair enough, just you made it seem simple, but it's not always easy to find something to charge the pin with, you oversimplified it.
Its been a long time since I made one but I seem to remmeber that a steel needle would be sufficient as most grades of steel are magnetic. Therefore it is influenced by the Earth's magnetic field whether you magnetise it or not.
I might be wrong. Been a long time since GCSE science classes.
Yes in theory, but the friction and other forces acting upon the needle would stop this from happening in reality, so a stronger charge needs to be applied to the needle to overcome it.
14,000V from an over head power line should suffice, just drape a bare copper wire over one :D
That's all well and good but useless if you are wearing a digital watch! ;)
http://www.learn-orienteering.org/old/nocompass1.html said:
Many people wear digital watches these days (I do myself, if I wear one at all). If you do, draw an analog watch face on a piece of paper, and then mark the hour hand on using the digital watch. The rest of the method is identical.
In the Southern hemisphere:
Place the watch on a level piece of ground.
Point the figure 12 towards the sun. For more accuracy, align the shadow cast by the twig with the 12 o'clock line.
The North-South line is the line dividing the angle between the hour hand and the 12 o'clock line in half.
In the northern hemisphere point the hour hand in the direction of the sun. The North-South line is again the line dividing the angle between the hour hand and the 12 o'clock line in half.
EDIT: Damn, soo slow, posted already :(
sorted! Worked out that I live in north belfast, worked out which way it is from here, thanks for all the help guise
Your office is directly SE of our house, just checked on Google maps. :)
But here, judging by the way you manage to get lost walking down a straight road, this information is probably no use to you... :p
Put a cushion in the ground, first walk forwards until you reach a pub, do the same in the left right and backwards directions.
If you enter the pub and the guy serving you is in a pink t-shirt and called tarquin, you have to use your VISA card to order a pint, that direction is south.
If you enter you pub, you can order a pint, a 3 course meal and spend some money on the quiz machine with only the change in your pocket your heading North.
If you enter the pub and it costs about the same as your local, your going east or west.
Dangerstat's guide to navigation;)
That's all well and good if we entertain the fallacy that any bank would ever trust me with a visa card
Find a church. Face the altar and you're facing East.
Moss on a tree
Needle/magnet water
get a decent phone
position of the sun
use a map and local features
speak to the person with custody of the office brain cell
