anyway thanks guys im not stressing about the errors in burntest much anymore. I think if I want to go over 3.6, I thinK some higher rated memory is needed and maybe a better cooler cos temps were in the 60's running burntest.
Phil, is your XMS2 C4 or C5.
My 4Gb of 800mhz C4 is rated to run at 2.1v. P35 boards have had a habit of underclocking memory, hence 1.8-1.9v.
This could be the reason for your errors.
Intel burn test is lethal, and stresses CPU's far far past anything else would, so dont worry about it tbh.
depends what your gonna go for, a bench testing rig, or a work/game machine. many a time some guy comes to a lan party with an unstable setup and has his machine bsod when gaming. that guy is laughed at real hard![]()
a failure in intel burntest is a failure none the less. some people are ok using thier machines on a day to day basis with a few errors being made. and some people prefer a error free stable setup.
as for phil, look on the bright side, if you got no errors at 3.8ghz id have asked you to trek on the 4ghz mark lol![]()
lol, im just about to use cpu burn to stress my system, here is my super pi and im on stock intel cooler @ nearly 4.3ghz, wish me luck
