My wife has been using a Laptop connected to a Monitor, keyboard & mouse but it has just died.
So, I am looking for a small, quiet PC which will be used mainly for Internet browsing, emails, family history & word documents. As you can see it does not need to be of a very high spec. I would prefer a small form desktop PC rather than another Laptop as it would take up less desk space. Most laptops in the cheaper ranges tend to be a bit noisy which is a problem.
Does anyone have any recommendations as to where I should look for a PC to fit my requirements or what bits to use to construct one.
I have looked at the Overclockers "Primo Pro" AMD Athlon X2 5600 2.90GHz SILENT DDR2 System, but this looks to be a bit too large & i am not sure how quiet it is.
Regards John
Regards John
