Hi there,
I'm having quite a big problem with a few of the MacBooks at the school in which I work. I was hoping someone on here might be able to shed some light.
We have a batch of 15 13" MacBooks, purchased sometime between 2004 and 2005, so they are quite old. Recently, the batteries have started doing odd things. To put it simply, they just die! And I don't mean discharge quickly or show limited life...I mean completely cut out...without warning.
To give an example, a MacBook will have been charging overnight. It is switched on in the morning and will show good battery life. After about 20 minutes of use, and when the battery is showing maybe 60% or so remaining, the power will just cut out completely, as if the battery had been pulled out. Given a few seconds, the laptop can then be powered back on (without a charger!) and will boot up fine. It will then very likely repeat the problem after a few minutes. This is all with the battery life still showing as adequate.
This incident is not isolated. It has begun occurring on about 7 of our 15 MacBooks within the last couple of weeks. Very odd!
Can anyone shed some light on the issue? I've tried resetting the SMC on all of the MacBooks by holding the power button with battery removed. This doesn't seem to have made a difference. Am I looking at 15 new batteries sometime soon?
Many Thanks
Many Thanks
