To be honest my macbook has been quite useless, I love it to bits but it really has been poor in terms of build quality. The first problem is that I dropped it (accidentally) low a very low hieght and the screen stopped working (which) I managed to fix after dismantling it and reconnecting some lead that connected to the top left of the main board. Then I picked it up by the screen itself (only softly) and the screen cracked which means that only 3/4 of the screen is usable now. Not a huge issue as I use with an external TFT, but all the same think they aren't built to last![]()
If I dropped my dell and picked it up by the screen id fully expect it to break
Apple does not recommend leaving your portable plugged in all the time. An ideal use would be a commuter who uses her MacBook Pro on the train, then plugs it in at the office to charge. This keeps the battery juices flowing. If on the other hand, you use a desktop computer at work, and save a notebook for infrequent travel, Apple recommends charging and discharging its battery at least once per month.
It affects all Intel MacBooks/MacBook Pros(Apart from the unibody MBs and MBPs, all previous models weren't limited if you took out the battery.. in fact it was recommended practice for those with near-constant AC usage)
The laptops aren't constantly run off mains AC, they are simply stored in a secure trolley, which has the secondary purpose of charging them.
EDIT: Upon taking a look at the Apple discussion forums, I see that literally hundreds of people are experiencing these exact same symptoms. yet no one seems to have come up with a solution...
Calibrating a Li-Ion battery (e.g. letting it drain completely, then do a full charge) is a bad idea.
Have a look on these very forums.. there are cases where people have killed new batteries because the battery drained so far it wouldn't accept a charge.
How to prolong lithium-based batteries (BU34)
Battery research is focusing heavily on lithium chemistries, so much so that one could presume that all portable devices will be powered with lithium-ion batteries in the future. In many ways, lithium-ion is superior to nickel and lead-based chemistries and the applications for lithium-ion batteries are growing as a result.
Lithium-ion has not yet fully matured and is being improved continuously. New metal and chemical combinations are being tried every six months to increase energy density and prolong service life. The improvements in longevity after each change will not be known for a few years.
A lithium-ion battery provides 300-500 discharge/charge cycles. The battery prefers a partial rather than a full discharge. Frequent full discharges should be avoided when possible. Instead, charge the battery more often or use a larger battery. There is no concern of memory when applying unscheduled charges.
Li-ion batteries should have an inbuilt protection circuit to stop this happening...Calibrating a Li-Ion battery (e.g. letting it drain completely, then do a full charge) is a bad idea.
