- 8 Apr 2004
Hello.
Earlier in the day when I was trying to sort out some of the hardware inside my PC, I accidently broken the SATA connection to my main hard drive. The model is the Hitachi Deskstar P7K500 320GB SATA-II OEM, which I bought from OCUK back in July.
Basically the extremely important plastic bit that sticks out along the 7 pins of the SATA connection got broken off and as you can tell, the SATA cable will be unable to connect. Even the pins are slightly bent which makes it more troublesome. I frustratingly tried to find a few ways to make sure a SATA cable is able to stick on somehow (i.e. electrical tape) but obviously it just won't work.
So I guess now my only option is to RMA the drive back to Hitachi? I don't know what their policy is concerning any slight damages to the drive, especially when its my own stupid fault, so I just wanted to know if I can RMA to replace it or not?
The drive only has the Windows O/S and games installed and nothing important so I'm not to worried about losing all that. I'm just really angry at how crap SATA connections really are.
