- 17 May 2004
50% now, so I'm looking at a 3 hour wait when I get home by the looks of it. I've even had a constant 8mb dl.
Check my X-fire profile its in there.
I have a Q6600 (stock), 8800GTS 320 and 2GB of RAM and it won't let me pick 1680x1050 unless I put it to absolute minimum. (Where the FPS is around 30)
what settings and framerate please.
If your game is running smooth then I cant understand why a 4870 wont run at even above 30fps![]()
as for screenshots, anyone know why i get a black screen from my printscreen button? lots of games do that for me![]()
Yeah, printscreen won't work (or work properly) with a lot of games. Games usually have their own key for taking a screenshot and when you press it, it will save the image to a folder automatically.
Yet with the PC version, you're going to need a particularly powerful machine to see it in all its splendor at a decent framerate, as even on our system (Core 2 Quad 2.40 GHz, 2 GB RAM, 768 MB GeForce 8800 GTX with Vista 32) we were having performance problems even after toning down a few of the settings, and some of the effects (the shadows in particular) didn't look so hot when displayed in high resolutions.
THE GRAPHIC SETTINGS OF GRAND THEFT AUTO IV PC
Most users using current PC hardware as of December 2008 are advised to use medium graphics settings. Higher settings are provided for future generations of PCs with higher specifications than are currently widely available.
Graphics settings are limited by system resources by default. 256MB video cards force minimum settings by default. If a user bypasses these safety measures using command line arguments and exceeds their system resources, the users gaming experience may be compromised.
Video Mode
Resolution scaling effects water, reflections, shadows, mirrors and the visible viewable distance. The resolution settings relate to the amount of available video memory. At 2560*1600 the game will require 320MB of video memory in addition to all the memory required for content. At 800*600 the game will require 32MB of video memory in addition to the content. Medium resolution settings are recommended for most users as higher settings are only usable if there is available video memory.
Texture Quality
Texture quality affects the visual quality of the content of the game. High setting for textures will require 600MB of video memory at a setting of 21 View Distance in addition to the memory taken by the Video Mode. A medium texture setting is recommended for most users.
Render Quality
Render quality is the texture filter quality used on most things in the world rendering. Most people would know this as anisotropic filtering. Medium settings are recommended for most users and will provide filtering beyond what the console versions can execute.
View Distance
View distance scales the distance in which different objects in the world such as building and cars are seen. Raising this option increases the distance in which high quality objects must be loaded and will increase the memory it requires. Restrictions are established to ensure the game runs optimally for most users. A setting of 22 or more will provide PC users an enhanced experience over the console versions.
Detail Distance
Detail distance scales aspects of the environment that the View Distance setting does not including vegetation, trash and other moveable objects. A setting of 10 would be the equivalent to the performance on a console. This setting has little effect on memory.
Vehicle Density
Vehicle density scales the traffic density of the traffic in the game. It has no effect on the mission vehicles or difficultly of the game, but can have a significant impact on CPU performance
Shadow Density
Shadow Density controls the number of shadows generated for positional lights in exterior environments. These shadows are exclusive to the PC version and can have a major impact on CPU and GPU performance.
Crossfire/SLI
With the latest ATI driver (8-11 series) the game supports crossfire modes (ie. 4870x2)
SLI is currently unsupported. Support will be added through a future game patch as well as an updated Nvidia driver.
NOTE: Background Processes
Certain background processes can have a detrimental effect on system performance when playing GTA IV, especially on systems with minimum required system memory. Users should ensure they disable their Virus scans (especially “on-access” type scans) when running the game to maximize performance.
